Home > Technical > Parking brake module |
smurtaza Member Since: 27 Mar 2018 Location: Minnesota Posts: 6 |
Update. Since motor was drawing too much power, took the module apart, removed the motor from transmission unit, opened one side of the motor and found it all gunked up with black stuff. Cleaned the motor with brake cleaning fluid, put it back together, tested and put it back in the module. Tested motor with transmission and cables attached and now it works great. It only draws 10 Amps as oppose to over 30 Amps before the cleanup. Going to put the module back in the car and adjust the brake shoes. Hopefully it'll all work fine. |
Thu May 03 2018 3:34am |
