squizzel
![](templates/vbnew/images/spacer.gif)
Engine fault and no codes | |
Hi all, a strange thing happened today and was just wondering if anyone has had the same experience. Today I had been pottering around from shop to shop getting various jobs done, so engine was nice and warm. Parked up on a car park but front end pointing uphill, dropped the suspension, and just as I went to switch the engine off....Engine fault appeared on the dash. Car was running fine, so switched off finished shopping and went home, no faults. Put the car on the Hawkeye and no faults logged.
I had similar to this 3 months ago, but I was convinced I was at fault then. I put some injector cleaner in for a full tank (I was on 1/4), drove to the petrol station and as I went to switch off Engine fault came up. I thought it was the concentration of cleaner going through, I filled up and never saw the fault again until today. There was no faults then either, so do you recon its just one of those querky range rover things or could there be an underlying fault that isn't triggering codes.
Thanks for the input
Tue May 01 2018 7:20pm |
