![]() | Home > General > Using a PS4 in car |
Not sure about PS4 as it requires a stable power supply done it with a PS3 and PS2 they were ok you would need a hdmi to AV connector which would be the easiest one to use i assume you have the AV inputs under the flap you show |
hawky666 Member Since: 12 Nov 2017 Location: Callington / saltash Posts: 6 ![]() ![]() |
Hi Geof.
Hi mine just sits under the passenger seat to be honest and I have a 2000 watt inverter which works ok plus I can run other items if I want which I ran a feed straight from the battery with an in-line on off switch also mine is not a permanent fixture so can change it with any other game station or lap top etc it under the seats as I think your saying would make it a bit harder if he wants to change discs or games |
I did look at that as a location but seems very cramped under their and didn't want him undoing seat belt etc to reach down. He's not great with his fingers etc due to light disability, so need to locate as easy to reach and operate as i can. Also he has a very short attention span so i'd be stopping all the time to change games if he can't get to it.
300 is fine I used double sided tape and Velcro |
simples always good.
You can get a hdmi to av from eBay and the onvertervto and maybe a cigarette plug for the end to plug it in the lighter socket temporarily for now to see if thar works and but the PlayStation undervthe centre arm rest on a board |
megabunch Member Since: 20 May 2018 Location: London Posts: 4 ![]() ![]() |
Would love to add a PS4 to mine - I'm a gaming addict! |
