Home > Technical > White exhaust vapour when starting up, slow coolant drain |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Yeah there's more vapour from the left side I think. I'll check when I take it out in a few mins. One side definitely seems worse than the other. Not sure if that points to either EGR or HG though. Is EGR a bigger job than HG, or is that an unknown?
Wed Apr 25 2018 11:10am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Sorry can't tell you either scope or cost as it was a warranty job done by a main dealer - two weeks before it ran out. |
Wed Apr 25 2018 11:39am |
Fair play - got it just in time then!
Wed Apr 25 2018 1:25pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
EGR should be a much easier job that HG.
Wed Apr 25 2018 5:02pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Is an option to consider blanking off the EGR permanently and then see what happens? Or am I talking out of my bottom again. Robin
Thu Apr 26 2018 9:29pm |
No.
Fri Apr 27 2018 10:41am |
Thanks all. I'm not comfortable bypassing them by myself, but I'm awaiting a call back from a garage nearby who have a good rep and do lots of LR troubleshooting so I think I'll get them to have a look at it. Fingers crossed it's EGR, but whatever needs doing will have to be done!
Tue May 01 2018 8:57am |
Car is in being looked at right now. Seems one of the cats is potentially damaged maybe by coolant in the exhaust, but yet to be seen. They found a water pump gasket and bolt in the under tray as well. I haven't had the water pump replaced and I can't remember if it was done previously, must have been I suppose! They ran a test overnight to see if any coolant was getting into the cylinders so I'm just waiting to see the outcome of that. Current feeling is the head gasket though by the sounds of it.
Wed May 09 2018 9:51am |
Its really good when you find a garage that appears to know what its doing. Fingers crossed Robin
Wed May 09 2018 2:41pm |
Gasket job being done and picking car up late next week. Eye watering bill. Going to see how the cat is after the gasket fix before deciding on when to replace it. Mechanic reckons it'll run just fine but it'll need doing obviously before the next MOT.
Fri May 11 2018 9:31am |
So theyve confirmed water in a cylinder and gasket gone. Are they doing both? 2019 5.0 SC SVA (Current)
Fri May 11 2018 11:34am |
They said definitely the gasket needs doing and they'd let me know if anything else does. They hadn't finished the full inspection yet. |
Fri May 11 2018 12:44pm |
