![]() | Home > Technical > Air suspension question. |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 ![]() ![]() ![]() |
On the dash screen Home menus, press 4x4 tab on left, you will get the screen below, look for any red bars etc above each wheel as an error, my my10 also had same error message, had to remove and service the air compressor unit, the air noise is probably from the exhaust valve on air compressor, some cars lift evenly others don’t from what I have seen, lift into full off road height, leave overnight and see if any corner has dropped, if not then hopefully no air leaks from any corner, if when you start raising or lowering the car it might show as overheating, if so another fault from air compressor, plenty of other reasons but start here first👍🏻
djb222 Member Since: 17 Apr 2018 Location: Birmingham Posts: 52 ![]() ![]() ![]() |
Thanks Paul,
David, did you get a warranty? Air compressor is just under the rear nearside passenger area, if you open the rear windows you should hear when it comes on and goes off, since I overhauled my air compressor I had no faults at all, repair kit is about £75, new compressor unit is around £300 oem, depends on which one you have, newer style is more expensive, if you have the older version and got the newer style then a software update is required around £100, hope this helps, paul |
I did have a warranty, however it's going back to the company I purchased it from as it must have been a preexisting fault.
Fingers crossed then all will be well👍🏻 |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
My compressor was over £600 fitted. Steve. |
