Home > General > Any one on here changed the brake vscuum pump on a 2.7?
beerguzzler
United Kingdom 2010 Range Rover Sport TDV8 HSE Baltic Blue
Hi.
I am looking to change the brake vacuum pump on my tdv6 2.7 2007. Has anyone done it before and would have some tips or a walkthrough? Or do you think its better getting it done by a garage?
Thanks
Post #554902 Tue Apr 24 2018 8:20am
I think it helps to be fit and slim to do the job!
Suspension is access / low mode
Remove grill.
remove engine cover (replace oil cap)
Then a case of either standing on a platform to reach the back of the engine to get to the 3 bolts
or sitting on the air box and doing it from there.
You may need to remove that metal water pipe to help get your hands in
Post #554920 Tue Apr 24 2018 11:06am
beerguzzler
Thanks.
I have had a look. I cant even see the thing, just the two pipe connectors. I cant even get my hands far enough down the back to reach the bolts.
I cant see it as something i will be able to do 😯😓
Post #554933 Tue Apr 24 2018 12:40pm
