![]() | Home > Off Roading & Green Laning > Mud, ruts and solid bits |
Try disabling HDC or if your car has auto TR2 leaving the TR in auto mode 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I don’t understand what you mean by slammed to a halt? When you let off the throttle? Sounds as though HDC was engaging as it automatically selects it when setting mud and ruts 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
It will not be HDC as it is speed related not surface condition related. Oh what is "auto TR2" - never heard of that in an early RRS.
TR2 and AutoTR2 are what is fitted to L494 RRS - TR2 pre 2015, Auto TR2 after ( yes I see the oP has a 2006 MY now!) The auto system is just that, the computers decide which mode Terrain response should be in rather that the driver and it refreshes the mode every 30secs to,a minute,IIRC, without disengaging the mode you were in. The auto mode is very good but I still prefer to choose which mode the system is in rather than have messages flashing across the satnav and TFT Dash advising that the “system is recalibrating” at frequent intervals
I think we need more info from HughN first. 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Thanks chaps.
HDC is activated automatically in Mud & Ruts. It wouldn't normally bring to a stand still though as the minimum control speed is above 0mph. I wonder if the centre diff was locked at the point you got to the firm ground. If both axles were slipping slightly and the centre diff was locked, as the fronts found grip, it might have caused the DSC to kick in.
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
I've never had that issue with mine using mud/ruts. |
No, neither have I but I'm just "thinking aloud".
I suspect it's the HTC kicking in, did it make a horrible grinding noise when you were stopping?
Nope ![]() |
DSC has nothing to do with active anti-roll bars - it detects and sliding/sideways movement (like when you loose it) even though you cannot feel it from the seat - DSC applies the brakes to correct the skid and drastically cuts power - it feels exactly as described in the original post. When offroading it can kick in and retard progress at the most inconvenient time. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
It certainly did. ![]() |
HDC then. |
