![]() | Home > General > PDC Volume |
The volume must be adjustable as mine is deafening to the point that it makes pedestrians jump when they start beeping! 2019 5.0 SC SVA (Current)
Yes it is adjustable if you mean the volume inside the car IIRC get it beeping and turn the radio volume adjustment, satnav instruction volume is adjusted the same way - it’s in the owners manual.........there should be nothing audible outside the car (it isn’t a truck...........) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I thought it must be, honestly you should see people jump out of the way when it starts beeping!! Thanks for the reply and to the OP, one less Q for me to ask. 2019 5.0 SC SVA (Current)
x3too Member Since: 31 Mar 2018 Location: Surrey Posts: 25 ![]() ![]() ![]() |
Thanks All - Just been outside to check mine , the volume doesn't work on the PDC speaker - It adjust the Sat Nav volume but not the Speaker . Mines a 2011 MY maybe a bit different?
Mine is a 2012 and works exactly as above, as soon as it beeps me using the volume dial adjusts from nothing to ear bending and all points inbetween. As long as my p button is lit up it beeps. |
Just checked mine to, 2012 MY and adjusts as described. My ears no longer bleed and pedestrians are now safe from heart failure! 2019 5.0 SC SVA (Current)
Also just found that when I have the radio on (or sound over the speakers) it turns that down so you can hear the PDC pips. I’ve read that the RRS Mk1 didn’t do that so I was surprised when it did. 2019 5.0 SC SVA (Current)
My One must be different been the 2011 - Any 2010/11 Owners care to comment? Are yours loud ? Cant believe both speakers for the PDC can be faulty - Nothing in the manual .
As far as I know there are no separate speakers for the PDC, it uses only a couple of the door or dash speakers for the audio system 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
2011 models..
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I think it was when they updated the interface for the screen etc. on the MY12 cars, the speaker is now integrated into the door speakers, and as such can now preset the volume in the system settings along with the likes of the phone ringing level, sat nav etc. as well adjusting it using the dash volume controls.
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
and the rear tone is lower than the front Merc C220 estate Sport AMG
Thanks Everyone for your help- Thats cleared the speaker locations/ equipment
I found another way to adjust the pdc volume which may work on the 2010 model (or may not lol).
