![]() | Home > Maintenance & Modifications > Range Rover Sport 2012 - MP3 Playback Fix |
Neat fix, though for audio quality reasons I prefer not to use lossy formats like mp3's. |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 ![]() ![]() ![]() |
What's the best quality file extension to use in this case ? |
I had an evoque previously and the issue wasnt file type as such but how the drive was formatted, eg FAT32 or EXFAT etc. I had a half terabyte drive hooked up in there permanently and all files were WAV or AIFF (essentially the same thing) 44k/16 bit.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
I have a few flac albums , they sound great . ![]() |
Yes, FLAC would serve a good alternative as it is lossless in data terms so essentially the same as WAV or AIFF in terms of CD quality replay. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1183 ![]() ![]() ![]() |
but the RRS' Meridian system doesn't play FLAC.
It absolutely did in the 2012 evoque I drove for 3 years with the meridian system. It is the disk format/hard drive compatability that is the issue. |
weird...
I have had that in my RRS. Perserverence. Try a hard drive. As I said, not all sticks or drives work. A pain and more to do with JLR system set up than anything else. There are alternatives which you could use eg tidal hifi stream via bluetooth will get you cd quality for 20 a month. Or rip the files to your phone and feed out via headphone jack to aux in. Or get a 2nd hand ipod etc.
Over on BabyRR.com (the Evoque forum owned by Martin) there is a thread with a list of all the memory sticks that will work in the same Meridian systems as RRS has. http://babyrr.com/forum/Thread-List-of-Mem...USB-socket 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tried a hard drive, no luck. Tried a Transcend 512Mb stick formatted exFAT, still no luck -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
See above ref to drives and sticks that work on the same system, or alternatively explore the alternatives.
What a |
Just to note .
