Home > General > Venting coolant
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Venting coolant
Changed stat today done exactly what said
In book to vent got air free bubbles tightened
Vent screws expansion cap on started up
within seconds hundreds of bubbles (air)
So before I take it up to 3000 r p m
Is this right does air come through
Expansion tank cap when screwed on
With bleed nipple shut or do I have to vent it with cap off
And bleed screw open or do I drain down and start all over again
Thankyou for any reply 👍 No friends no favours
Post #554764 Sun Apr 22 2018 6:14pm
Don't know where you mean this air is.
I always run a car for at least 5 mins with the cap off to let it sort itself out.
Also Give it a little rev to pump the water round
Post #554770 Sun Apr 22 2018 6:52pm
Bullnogger
The air is coming into top of header tank
Returning through black hose off top of
Radiator No friends no favours
Post #554771 Sun Apr 22 2018 6:56pm
Bullnogger
Basically does the air returning to header tank
Vent itself through expansion tank cap when closed
or do I vent it through black plastic vent cap
While engine running
Thankyou for your replies No friends no favours
Post #554778 Sun Apr 22 2018 7:41pm
I think you need to use the black vent plug. The cap doesn't vent, I believe. 2012 SDV6 - it's missing a couple of cylinders
Post #554781 Sun Apr 22 2018 8:37pm
Radiator
That's good.
Air is coming out of the rad and water allowed in the bottom.
Post #554788 Sun Apr 22 2018 9:47pm
