![]() | Home > Technical > Reverse Camera Yellow Lines |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
They only bend if the car has the surround camera option fitted on the RRS1 at least.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Col may be right. My 2010 has surround camera and bendy lines. I did test drive a few but can't recall if they all had bendy lines. I remember being aware that if no lines and the screen shows a "mirror" image the camera is goosed, it was on my check list. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
My 12 plate doesn't have surround cameras and the reversing lines stay straight. 2012 SDV6 - it's missing a couple of cylinders
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
No bendy lines on mine, but I do not have surround cameras.
Thanks Gents, I don’t have the surround cameras so must be correct. The reason I asked is because a friend has an XF and his bend with the steering input. Just seams a little daft really, not that I actually use it though. 2019 5.0 SC SVA (Current)
