Home > General > LED interior lighting
shepp
Cymruambyth wrote:
I bought these. The only ones which were the wrong type were the visor ones which didn`t bother me. 6 months on and still ok.
https://www.ebay.co.uk/itm/RANGE-ROVER-CAN...SwCGVX2rNl
I bought the exact same ones, they started to fail within minutes. Also the base was to thick and bent some of the contacts. i contacted the seller who happily sent me a replacement set (slightly different bulbs) which have lasted around 2 months and some are starting to flicker. Both types of bulbs looked like the cheap Chinese type, poor build and quality.
The only way to ensure quality is to spend big bucks on Osram or Philips. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #553758 Tue Apr 10 2018 10:45pm
Smarttech
I got my kit last week and have only fitted the odd one or two bulbs so far as they are not as bright as the old ones they are ment to be replacing and do look like cheap Chinese bulbs. Not sure what 4 of the bulbs are for as not found any of the used in the sport. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #553767 Wed Apr 11 2018 7:07am
PDC
I opted to go with Osram on the exterior lighting and glad I paid the extra now for the hassle free fit and forget!! Thumbs Up 2010 RR 5.0 Autobiography
2020 F-Pace SV
2018 RRS HSE Dynamic 3.0
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #554016 Fri Apr 13 2018 1:29pm
Brit Plumber
I’ve just finished installing my kit from precision LED and they look pretty good so far. Had an issue with the vanity mirror LEDs, as they are not premium (due to the size required) they only work in one orientation. Unfortunately I blew a few fuse on the first attempt and decided I’d leave it until I can identify the correct way round to install them. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #554079 Fri Apr 13 2018 8:37pm
Scrumpy
Don't do what I did when changing the LED bulbs and blew a fuse!
I pulled what I thought was the right fuse, then realised it wasn't, I put it back and the engine started (no key in ignition!!).
I couldn't turn it off and had to pull the fuel pump fuse to get the engine to stop!!
Turned out I blew the BCM (Body Control Module) and cost me £2,500 to get fixed!!!
Heed my warning!!! Dumb mistake, lesson learned but hope no one else ever makes the same mistake as me! Embarassed 2016 RRS SVR Estoril Blue
Post #554098 Fri Apr 13 2018 10:10pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Thought that I would add my experience to this thread.
I purchased a LED interior lighting upgrade kit on eBay from a Chinese supplier. Initially I was pleased with the kit and the LED bulbs gave a much brighter white light with no Canbus errors and easy to fit. But, after 3 months the bulbs are starting to become faulty 1 by 1. One of the LED 'panels' on each of the faulty bulbs has started to flash on and off. I fitted a total of 11 bulbs and 5 are now faulty with a very annoying flashing strobe effect.
Lesson learnt, don't buy cheap import LED bulbs; you get what you pay for!
I think that I will exchange each of the bulbs, as they become faulty, with a quality Philips or Osram alternative as suggest by Col earlier in this thread Thumbs Up
Post #554340 Mon Apr 16 2018 9:40pm
Cymruambyth
Wales
That`s a shame. Mine are fine so far....crosses fingers Very Happy Steve.
Post #554344 Mon Apr 16 2018 9:55pm
Even the Philips one's are made on China Rolling with laughter but obviously far superior quality. Thumbs Up
Post #554365 Tue Apr 17 2018 5:52am
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Yes, I did the same, w5w in white and blue for the interior, I did get the number plate led kit from,powerful uk, put in 2017, all still working fine Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #581330 Sat May 25 2019 11:36am
