![]() | Home > General > Can I fit LEDs to side indicators? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Yes I believe so. They are on the same circuit as the rear indicators
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Yes |
Thanks everybody. 2006 2.7 TDV6 HSE in Cairns Blue. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I fitted LED bulbs to the side indicators. They work with no problems and I had no problems fitting them. |
Do you mean you`re putting orange lenses on and you want normal clear, orange flashing bulbs? Steve. |
I currently have clears with orange bulbs, but thinking of going to orange lenses with non coloured bulbs. 2006 2.7 TDV6 HSE in Cairns Blue. |
The general rule of fitting LED bulbs is use red LED bulbs for red lensed lamps, orange LED bulbs for orange lensed lamps and white LED bulbs for clear leansed lamps (reverse). If you use white LED bulbs in either red lensed lamps or orange lensed lamps the emitted light has a very washed out look. |
Right, with you now ![]() ![]() |
These are the LED bulbs I use in my door mounted indicator repeaters.
Again thanks everybody |
