Home > Faults & Fixes > Red suspension light coming in when going round left corner
Nico2104
On my 2005 range rover sport supercharged i have my red suspension light starts flashing and then stays on when going round left corner but it mainly only does it when it's been raining, in the dry it is normally OK. It has come in after a long drive such as 3 or 4 hours but again when I go round a left corner. If I switch the car off and back in the light goes out until I swing round a corner again. Any help would be appreciated. Cheers
Post #553992 Fri Apr 13 2018 10:21am
Cymruambyth
Wales
Do you mean this one...but in red?
Mine does the same. Usually a quick stop and restart sorts it. Mine is very intermittent though, so difficult to diagnose apparently. The codes mentioned a CANBUS issue but I have to wait for it to get worse to sort it Rolling Eyes Steve.
Post #554002 Fri Apr 13 2018 11:10am
Nico2104
Hi yes that's it, mine sometimes comes on yellow saying, "fault when cornering" but it's mainly red when it does it. It's done it every now and again for ages but with all the wet weather it's doing it all the time but only when turning left. Cheers
Post #554004 Fri Apr 13 2018 11:15am
Cymruambyth
Wales
And does it say max speed 30mph....and feel like you`re driving a clown car? Steve.
Post #554008 Fri Apr 13 2018 11:41am
Nico2104
It doesn't lower the suspension or put it into limp mode. It drives normal and suspension stays in normal height. Cheers
Post #554013 Fri Apr 13 2018 11:52am
Cymruambyth
Wales
So yours is the ride height warning light then...not the tippy over one Very Happy
When I first bought mine it wouldn`t go up or down and that light was on.....seller fitted a new compressor! Steve.
Post #554049 Fri Apr 13 2018 5:22pm
geoffsnook
Checked the fluid level yet Question
Post #554051 Fri Apr 13 2018 5:47pm
Nico2104
Yes mate, 1st thing we checked was the fluid level, the suspension light comes on only when going round a left corner or if you park and the car is leaning to the left. Compressor seems fine, car pumps up and goes down really well. It's just the fact it does it mostly when the roads are wet and when going round left bends/corners. Got us baffled to be honest.
Post #554052 Fri Apr 13 2018 5:50pm
geoffsnook
Got any codes for us Thumbs Up
Post #554055 Fri Apr 13 2018 6:02pm
Nico2104
I cleared all the codes previously as advised and these are the ones that stay on. Cheers
Post #554057 Fri Apr 13 2018 6:07pm
geoffsnook
If you drive it and it comes on do any of the sensors on the 4x4 screen go red or have you not looked yet as i think they are just generic codes you could do with a read from a land rover specific code reader Thumbs Up
Post #554061 Fri Apr 13 2018 6:43pm
Nico2104
All sensors are reading fine, I did have a height sensor replaced at a place about 2 months ago and the side they fitted to has sat 20mm lower than the others. I think if no luck on here I'll get I booked in somewhere next week. I just don't want them telling me it's this and it's that as I've had it before where they tried to charge me a fortune for something that didn't cost much at all. Cheers
Post #554062 Fri Apr 13 2018 6:47pm
geoffsnook
Have a look at this topic does any thing fit with your issue's Thumbs Up
http://www.rrsport.co.uk/forum/topic21130-15.html
Post #554063 Fri Apr 13 2018 6:48pm
Nico2104
Nothing really in thereatched mine, the car drives absolutely fine even when the red suspension light is on. If I switch the car off it dissappear a until I swing round d a left corner but like I say if its been dry for a few days it doesn't really ever do it. Its more when it's wet or been a freezing/damp night or day. I did speak to a place I have used but there a 4 hour drive from me, they said it sound likes maybe the wiring that goes to the lock in the back of the car as its exposed and common for the wiring having breaks especially as it comes on more in the wet.
Post #554066 Fri Apr 13 2018 6:55pm
