Home > Detailing & Car Cleaning > What is your recommended chip/scratch repair product?
wilchesth
United Kingdom 2008 Range Rover Sport TDV6 SE Zermatt Silver
I have had my RRS for over 2 months and I noticed that some chips have suddenly appeared after several washes in what I think it was a poor cover up of chips which was possible done prior to be sold. I’m going to touch them up again but I thought I better use a better product. So far I’ve come across with lots of touch up pens and also kits from chipex which to me sounds to good to be true. Anybody here got a recommendation for a long lasting product? Anybody used chipex?
Post #553752 Tue Apr 10 2018 10:03pm
shepp
I tried chipex on my previous sport. It was unsuccessful. The paint just wiped off. I am usually fairly good with these things I couldn't get a satisfactory result. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #553754 Tue Apr 10 2018 10:14pm
wilchesth
I also came across with a Land Rover kit from ebay for £20.50 for Zermatt silver but with so many stories on Fake Britain can’t trust ebay for a genuine product.
Post #553759 Tue Apr 10 2018 11:06pm
Cymruambyth
Wales
I`ve used the company Chipsaway in the past, very pleased with them. Obviously they`re a franchise and depends on the individual but I assume they`re all trained to the same standard Thumbs Up Steve.
Post #553774 Wed Apr 11 2018 10:34am
Brit Plumber
Having done few chip repairs in my time, I find for best results you need to really clean the chip to get rid of the dirt and possibly polish/wax. Once you have got it clean you need to prime if it’s to the metal and then apply the colour. When it’s dry, remove any paint you may have got outside the chip and let it harden. Then use a good clear coat (I use a 2 part in v small amounts) to fill the chip above the original paint. When that to is hard I use a hard pad with cloth over it to polish over the chip and level the surface off. It is normally visible if you know where to look but it’s a much better result than just leaving it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #553780 Wed Apr 11 2018 12:49pm
wilchesth
What make did u use?
Post #553781 Wed Apr 11 2018 12:58pm
wilchesth
What do u guys think of this one?
https://m.ebay.co.uk/itm/GENUINE-LAND-ROVE...0617786567
Post #553785 Wed Apr 11 2018 2:35pm
jimbg
Cheaper
https://www.lrparts.net/vep501730mbk-zerma...c-798.html 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #553786 Wed Apr 11 2018 2:40pm
wilchesth
It's £22.31 including VAT and delivery. I think I'll get it anyway.
Post #553787 Wed Apr 11 2018 3:33pm
Brit Plumber
I’ve used all sort of different brands of paint and it’s all very similar, stone chips are so small it doesn’t really matter. It’s all in the prep and care taken. A good clear coat to seal the paint is a must as the colour coat is very soft and will likely get washed out. A 1k clear coat will probably work ok but I use a 2k coat as I have it on hand from rebuilding my bikes. 2019 5.0 SC SVA (Current)
Post #553847 Thu Apr 12 2018 6:22am
