Home > Technical > auto lights not working
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
Any one know why my auto lights don't always work, some days there fine, and others I have to switch them on manually Crying or Very sad
Post #553583 Sun Apr 08 2018 10:12pm
When you say you have to switch them on manually, do you mean you have to turn the switch from the auto position back to normal headlight position then back to auto, or turn them completely off and back to auto again?.
Post #553584 Sun Apr 08 2018 11:06pm
blueiceplus
no sorry I have to turn them to the on position , as they don't work in the auto position at all
Post #553588 Sun Apr 08 2018 11:18pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Loose connection or contact point in/at the switch, or a similar issue at the sensor ?
Post #553597 Mon Apr 09 2018 8:02am
Have you checked fuse No.18 in the passengers side fuse box? as this appears to cover the Light Sensor for Auto Lamps, also covers Rain Sensor but if rain sensor works then would appear fuse is ok.
Post #553598 Mon Apr 09 2018 8:48am
blueiceplus
ok thanks do you know were I will find the sensor ?
Post #553657 Mon Apr 09 2018 7:50pm
I believe the auto lamp sensor is mounted on the windscreen behind the rear view mirror, as I think it is an integral part of the rain sensor. Possibly check Fuse 67 as well.
Post #553669 Mon Apr 09 2018 10:22pm
