Home > Maintenance & Modifications > Aluminium Pedal Covers |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
Hi there,
Sat Apr 07 2018 5:22pm |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
Shame they aren't a more straightforward fit but must admit well worth the effort as look really good |
Sat Apr 07 2018 5:26pm |
Hi dobbo9,
Sat Apr 07 2018 5:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
On later facelift cars L/R decided to change the design of the actual throttle pedal, which is why the throttle pedal cover is a pain to fit, as I discovered when I fitted a set to mine a while back. I ended up using a pedal cover from a different L/R kit which did not need the pedal drilling and cover bolting on although I had to take a dremel to the pedal instead, so it was which is the lesser of two evils. They fit earlier cars no problem as I had one on my old 09 plate car, the kit's get advertised as fitting 05-13 cars which isn't strictly correct.
Sat Apr 07 2018 9:23pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
They would have been much cheaper from Powerfull.co.uk
Sun Apr 08 2018 11:10am |
