Home > Tips & Tricks > Heat gun to bring back the black |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
I’ve never heard of this before so just had a Google to find out a bit more, from what I can see it does seem to work, however it doesn’t appear to last that much longer than using a trim dressing, also some people seem to say it’s quite hard to get an even finish/colour across the whole trim assembly. So I don’t think I personally would try it, but if you do I'd be interested in seeing the results. If worst came to worst and the panel was damaged I think a new one is only about £60 so it wouldn't be the end of the world if you needed to replace it. |
Sat Mar 31 2018 8:24am |
Don’t bother unless your doing it to sell a vehicle as it only lasts a few weeks then it’s back to light grey,I tried it.Im yet to find something that lasts.
Sat Mar 31 2018 8:27am |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
Yeah I’m the same keep trying different things it just looks so tatty being that dull grey, perhaps I should just buy a new one |
Sat Mar 31 2018 9:00am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Search for ‘Wipe New’
Sat Mar 31 2018 9:28am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I bought some Aerospace 303 trim restorer as I really rate the 303 protectant.....I`ve not used it yet but it seems good stuff. Loads of youtube vids.
Sat Mar 31 2018 1:11pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 884 |
Gtechniq C4 trim restorer, brilliant easy to apply, a little goes a long way as you get a tiny bottle but it is more than enough to do all the trim on a Range Rover. Lasts for about a year |
Sat Mar 31 2018 10:59pm |
That’s the one, works the same way as Wipe New, a permanent chemical reaction. Again, takes a long time to go off and any rain will result in streaking, but applied well it makes an almost permanent restore. |
Sat Mar 31 2018 11:27pm |
I use anything with a high silicone content, the plastic will absorb it and you need to apply it until it stops absorbing the stuff and wipe off the excess. I think the heat gun method brings the silicone to the surface which in effect is taking more from within the structure. 2019 5.0 SC SVA (Current)
Mon Apr 02 2018 10:28am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
This may sound silly, I used Peanut Butter Smooth. I think it is the oil in it that does the job itisme |
Mon Apr 02 2018 5:12pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
+1 |
Tue Apr 03 2018 7:08am |
grey17 Member Since: 18 Jul 2016 Location: London Posts: 62 |
You can clean most of it off with steel wool kept wet with soapy water prior to using a back to black product. (I'm talking only about the scuttle panel at the bottom of the windscreen).
Thu May 10 2018 4:05pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 398 |
I had mine replaced under warranty. Not only did it go grey/white, the surface deteriorated so badly you could scratch it if you used your finger nail lightly. |
Fri May 25 2018 10:15am |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Try wurth bumper dye. Im not a fan of the heatgun method as after a few years you can have very patchy bumpers. |
Fri May 25 2018 11:39am |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 |
Painting it will be the only guaranteed way of keeping the panel black... |
Sun Feb 16 2020 3:29pm |
