Home > Maintenance & Modifications > New wiper arms |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 402 |
The wiper arms can be quite hard to remove if they are jambed hard on the splines. I have no doubt that some people would twist the base of the arm from side to side to remove the wiper arm which can distort the wiper linkage. This may be your problem. I use a special puller to remove wiper arms from the spined shaft which does not impose any bending force on the wiper linkage.
Sat Mar 31 2018 9:53am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
I just carefully used a standard 3 leg bearing puller, but just used 2 legs. Came off easily. I'm in the shed, I'll be back in the real world in a minute. |
Wed Apr 18 2018 5:00pm |
