Home > Technical > Tow Bar Too Long? |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702 |
It sounds as if some one has changed the lock and it has fallen apart and not been put back together properly had it with mine and it took me ages to get it right |
Mon Mar 26 2018 6:43pm |
alex31283 Member Since: 16 Jul 2016 Location: York Posts: 8 |
Cheers for all the help everyone. |
Mon Mar 26 2018 7:06pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Had exactly the same issue with mine when I first used it, brand new L/R hitch and the car had never had one fitted before so the receiver was unused as well, changed the lock because I thought that was the problem, but in the end had to dress up the receiver slightly as it wasn't allowing the locking pin to fully engage in the receiver, now fit's a releases perfectly with no problems. Haven't used it a great deal but absolutely no sign of the "loose fit" issue that they have either.
Mon Mar 26 2018 7:45pm |
Cheers for all the help on this people. Ended up getting it to fit using a file, loads of WD40 and some elbow grease to get rid of the built up grime and rust. |
Wed Mar 28 2018 2:10pm |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Wed Mar 28 2018 2:47pm |
