![]() | Home > Technical > Tow Bar Too Long? |
Hi and welcome
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
If it’s the detachable tow bar you’re talking about and specifically the attachment to the RRS then it might be that you just have to be more “assertive “ with it. But as Riverblanche says pics would help. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
alex31283 Member Since: 16 Jul 2016 Location: York Posts: 8 ![]() |
Sorry about stating what's probably the obvious, but have you checked the workings of the tow bar without it being fitted. As far as I can remember, if you push the little silver protrusion, then the tow bar locks into place. Obviously you can't fit it if the tow bar is in its locked position so just check that you are not trying to fit it whilst locked. Once again I'm sure you've sussed this but no harm in just checking... Robin
Hi Eaters,
I'll go and check mine. Photos may follow but the pin doesn't disappear altogether even when locked. Robin
So Picture 1 shows the tow bar ready to be fitted - note that the main locking bar is fully retracted
Cheers Eaters. I'll take a look when I get back home. |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Mend with a disco 4 was having the same problem and he wasn't actually pulling out the spring loaded green sleeve where the key is. He had just turned the key and it won't go in unless you also pull the green bit so that you can see the red collar. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Good point Godders.
Thanks for the assistance guys but I've tried and its like the large silver protrusion can't reach the hole on the receiver to go through and then lock into place. Could it be the receiver that's damaged? |
That was exactly what was happening with my friends tow bar until he pulled the green bit away from the body Can you push the small silver pin in with your finger when it is unlocked ? Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
The receiver can rust inside and get full of all sorts of grime and dirt so would be best to clean that out first, then give it a spray of WD40 and have another go |
Gooders, the small pin pushes in slightly but not a huge amount.
