![]() | Home > Maintenance & Modifications > Android install |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Looks tidy. Was it difficult to do? Steve. |
Very easy pal suprisingly. Took about an hour to cut and bond the fascia. Cable kit took a couple hours. |
Does the top screen still work though? Steve. |
Yes mate. Im in the process of swapping it for a 2010 one |
Nice. Usually this sort of job costs an arm and a leg, that`s why I`ve stuck with the old outdated system. Steve. |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
A Write up of parts used would be interesting |
hi Devon this is the radio i used. and the fascia will also link the adapters for other bits
Excellent, thank you very much |
Did you also use the incartech kit for the top screen |
yes I have now fitted a 2010 Range Rover top screen tho. All works fine. |
