Home > Faults & Fixes > NOT my day! Now can’t open tailgate!! |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
How common is it for the actual button to be faulty.? It’s taken me several hours many thumps a lot of swearing and kicking the waste bin over! In the end It was ust the non stop get jabbing at the boot button then all of a sudden I heard click and the boot popped open. So I’ve removed the interior panel for now (just in case,) but I’m wandering if it may be the actual button that was at fault. |
Fri Mar 23 2018 8:59pm |
Could these be related issues? i.e. common connector, earth or loom etc. 2019 5.0 SC SVA (Current)
Fri Mar 23 2018 10:39pm |
I have no idea, was hoping someone was going to say that though. |
Sat Mar 24 2018 7:43am |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
I've got the same problem it worked perfectly when I checked at the dealers got it home and it wouldn't open. Took out the switch and it looked brand new but tested it any way working fine so either a broken connection or lock has gone bandit but I'll live with it for now. If it ain't broken down it soon will
Sat Mar 24 2018 9:29am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
2 things to note to eliminate the switch
Sat Mar 24 2018 10:29am |
Tried the button on dash thing, nothing happened. Does the ignition need to be in a certain position?
Sat Mar 24 2018 10:36am |
maybe the car might benefit from a battery disconnection for 15 mins
Sat Mar 24 2018 12:22pm |
Car just needs to be unlocked for the dash button trick to work.
Sat Mar 24 2018 1:33pm |
