Home > Faults & Fixes > Fuel gauge reading empty when full...
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
All sorted
Post #552105 Fri Mar 23 2018 3:40pm
Oldandconfused
This any good to you?
http://www.rrsport.co.uk/forum/topic28125....fuel+gauge
The reason I saw this was because after a battery change a few weeks ago, mine dropped to zero on the way back from the indi I use, but then within 5-10 seconds bounced back. Did that twice on that journey and twice since but otherwise fine.
Post #552110 Fri Mar 23 2018 4:50pm
riverblanche
Hi, as OaC has highlighted ^
dodgy wires on top of the sender unit, which I think is on top of the tank, the reason for taking in with 1/4 tank if they have to drain or drop the tank to access
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #552111 Fri Mar 23 2018 4:59pm
Danv8
sorted
Post #552112 Fri Mar 23 2018 5:03pm
riverblanche
on ours it was NOT a software issue, it was the wiring on top of the sender that was at fault and needed replacing
not sure the route the wires take but try and trace backwards from the sender unit
Post #552114 Fri Mar 23 2018 5:10pm
Danv8
Don’t suppose you remeber the cost? Pm me if you don’t want to post publicly, just want to know what I can do with this guy coming to look at my car regards purchase price etc.
Post #552117 Fri Mar 23 2018 5:49pm
Oldandconfused
Is this a LRJ TSB that refers to your problem? Don't know if you would have any luck bearing in mind the age of the car;
LTB00566v6
Just found this;
http://www.rrsport.co.uk/forum/post541311.html
Post #552140 Fri Mar 23 2018 8:58pm
Danv8
Can only but try, have sent Col a pm hoping it can help.
Post #552145 Fri Mar 23 2018 9:50pm
riverblanche
as in the other linked post, the dealer contacted CRC to get it done as the "approved" warranty would not cover it as "known issue" Evil or Very Mad
so not sure of cost its more about the labour to get to it then do the repair Rolling Eyes Porsche Cayenne 2022
Post #552147 Fri Mar 23 2018 10:06pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I had this problem with my Facelift 2009 Sport, three years ago.After a bit of research. I was told that Landrover were aware of this problem( it was the wiring on sender unit. It entailed dropping tank and changing wiring connections on sender unit. Main agents denied any knowledge of this. But after contact with customer services, they did the job without cost. itisme
Post #552169 Sat Mar 24 2018 9:54am
Have replied to pm, but just remember there is a pdf copy in my gallery which can be downloaded File No. 37 however the bulletin is for the facelift variant of the RRS1.
Post #552176 Sat Mar 24 2018 11:00am
Danv8
Awesome thanks Col.
Post #552179 Sat Mar 24 2018 11:37am
Danv8
Where can I get customers services contact details?
Post #552180 Sat Mar 24 2018 11:38am
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Had the same fault about 6 months ago (2011 RRS). Got the same link from Col and forwarded it to our local Indie. Tank was dropped & sender unit connectors changed. Worked correctly since. Think I was charged about £80.
Post #552299 Sun Mar 25 2018 11:06pm
Danv8
Fingers crossed but All working now, i removed the drivers wheel and dried out the wiring connectors i found behind the inner wheel arch using a heat gun, whether by pure chance or luck after this its been fine for the last 2 days, I did put the pressure washer right up into the archers when i gave it a clean on friday and it was the first time this happened directly after i left the jet wash.
Post #552306 Mon Mar 26 2018 8:05am
