![]() | Home > Technical > Timing Belt Tensioner Failure |
I don't get your drift. But warranty company should pay out.
ask the warranty company to prove it was not fitted properly |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
continue with your claim under warranty and let the warranty company pursue the garage !! Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
If the belts were done 3 years ago, they can hardly claim it's a known failure issue. Tell them to pay or answer to the ombudsman.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Is this a case of the oil pump casing failing that is a well known issue with certain 2007 /VIN range?
