![]() | Home > General > MOT Brakes Tested On Rollers... |
Cant see how you can check brakes on an mot rig as it will not stay in the rollers it would drive itself out so on way were th brakes checked properly |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I've just had my car get its French MOT (control technique...which lasts for 2 years.. yay) and when they do the brake tests they put a frame of free rolling rollers under the wheels not on the road rollers. I have never had a 4 x 4 have an english MOT so have never seen them tested any other way. Mine passed and not noticed any problem or difference with braking since. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Watch this YouTube clip
You cannot test the brakes on the rollers for a vehicle that is in constant 4 wheel drive,,you have to use a Decelerometer,,on some 4x4’s you can test the park brake in the rollers.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Well hopefully he was just bluffing then, going through the motions to look the part?
Well this definately was not done, then rears were stationary, as were the fronts when rears turning. I just can't see how the RRS could have been driving or the traction control would surely have been going haywire? 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
Some mot rolling roads have 4x4 function where it turns the wheels in the rollers in opposite directions. This stops the prop from turning as it is just working the open diff.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
thanks for some sensible input Rich |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Exactly so. The RRS centre diff is open in normal conditions so you can spin up one axle without harm. The Freelander (and early FFRR L322) has a viscous coupling as the centre diff and this will be damaged by a single axle being spun up. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thats good news then, all I'd previously heard, and read on other posts here was that fixed 4x4's should not be tested on rollers.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
When I had my Scooby I made the tester take it on the road to test the brakes....never even thought when I took the Sport the other week |
Your Scooby had a Ltd slip diffs so would not be able to be brake tested, if a vehicle has a locking or Ltd slip or viscous coupling centre diff then the wheels must be rotated in opposite directions. If the vehicle has Ltd slip or locking front or rear diffs then it must be tested using a decelormeter . If the vehicle has open diffs them it doesn't matter. Also to add electric locking diffs or just open diffs with a locking mechanism so can be tested normally |
Ahhhh |
