![]() | Home > General > osram xenarc 4300k or osram night breakers 4800k |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I would do neither. The OSRAM Night Breaker Unlimited bulbs are a much better option. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
If you're replacing the xenon you'll need to go Xenarc.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Controversially you could always replace the H7's with LEDs, I did and haven't looked back. I started a thread on here with some details for the ones I ordered (which are still as good as the day I bought them!) |
I concure with Wayneclarke. Changing the halogen H7 bulb for a LED replacement is a positive move. I fitted 6500k Phillips LED bulbs and the additional high beam performance compared to using a halogen bulb (even the best halogen bulb) is significant.
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 ![]() ![]() ![]() |
It was because of your thread that i also went for LEDS and they're fantastic |
I got the member wrong
