Home > Technical > Handbrake effort
d-9
Handbrake effort
I've just replaced my handbrake shoes, done the bedding in procedure, but not sure if it's set right.
How hard should he car lurch when pulling away with the handbrake on?
Previously, you definitely knew the brake was on, with a bit of a lurch before it had taken the brake off. Now it's very smooth, like you don't know it's there. Was it set wrong before, or do I need to tighten it up?
Post #551409 Thu Mar 15 2018 12:10am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
My L320 was always smooth with no jerk on takeoff!
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #551516 Thu Mar 15 2018 7:44pm
d-9
Thanks Smile
Post #551550 Fri Mar 16 2018 12:01am
My TDV8 was always smooth when driving off the handbrake. The times it was jerky usually presaged an adjustment being required (or a repair, in a couple of cases).
These days I usually use the button to disengage EPB before pulling away. 2012 SDV6 - it's missing a couple of cylinders
Post #551571 Fri Mar 16 2018 11:01am
d-9
Thanks RRSTDV8, it looks like the garage was a bit excitable when they adjusted it up previously. I'll go park on a hill and check that it holds the car.
I usually take it off manually because it feels like I'm punishing the car driving off with the brake on, but its mostly a measure of wether I've adjusted it correctly.
Post #551577 Fri Mar 16 2018 12:19pm
