Home > General > Knocking noise and vibration
On a hard left turn I get a knocking noise and vibration through the steering. Would suggest that noice and knocking occurs when the wheel turns one full revolution - any ideas, has this happened to anyone else?
Some serious answer would be good! 2005 Zambezi TDV6 - Gone but not forgotten
Post #55025 Tue Sep 12 2006 3:29pm
I get this sometimes in reverse, with full right lock on...
I'd assumed it was normal for 4x4s as the wife's FL does it too.
Not sure I'm describing the same problem as you have though, VA.. Confused
Post #55031 Tue Sep 12 2006 3:53pm
It doesn't happen on the hard right turn. Looks like I'm going to jack the car up, take the wheel off and have a look! I have a feeling this might have occured after my mud bath in Berkshire - I jet washed the underside of the car last weekend and stil had heaps of mud there, there is probably a stone lodged in somewhere. 2005 Zambezi TDV6 - Gone but not forgotten
Post #55034 Tue Sep 12 2006 3:58pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
VA, your knock sounds like it could be a suspension damper creak / knock. It's difficult to tell by description alone. If it is really annoying i suggest a trip to the 'stealers'.
Shmoogle, it sounds as if your knock could be caused by the steering bump stops. Do you only get it on full lock in reverse? Or do you also hear it when you change from reverse back towards a forward motion? Do you get one loud knock and then nothing else, or does it knock everytime you reach full lock? Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #55037 Tue Sep 12 2006 4:05pm
TB, mine only occurs in reverse on full right lock. Doesn't happen reversing to the left or at any other time... never thought anything of it, as Mrs S's Fl does exactly the same thing.
Post #55038 Tue Sep 12 2006 4:08pm
caz
England 2005 Range Rover Sport Supercharged Java Black
I have a very faint sensation of vibration when turing left sometimes, usually when the car is cold. It feels like a slight knock through the steering....maybe a problem in the making...god I hope not! Crying or Very sad
Post #55039 Tue Sep 12 2006 4:16pm
Cliff H
As TB says the 'knock' on full lock could well be the bump stops, a small amount of grease on them and all is fine. Vibration, not sure. Is the power steering fluid level OK?
Post #55041 Tue Sep 12 2006 4:22pm
Bobby
Funny... when I reverse in full lock it feels like I went over something. This has happened on a smooth surface and I've got down to check - nothing there. Its a feeling like you just went over a pencil... Mad
This only happens sometimes though! Confused Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #55103 Wed Sep 13 2006 12:07am
It doesn't feel as though as it's doing any damage.... but greasing my bump stops sounds like fun!!
Post #55124 Wed Sep 13 2006 8:46am
Bobby
Shocked Shocked Shocked
Laughing Laughing Laughing Malaysia Boleh!
Post #55126 Wed Sep 13 2006 8:51am
freddi
Australia 2011 Range Rover Sport Supercharged Fuji White
Knocking when turning Left
Ihad the ame problem, the service techs said it didn't sound serious until they changed the steering rod.
I only felt this when turning left power out of the turn
RR apparently had a circular sent out just in case somebody had this problem which I did am sure many others do as well.
good luck Love the sport. First the 2005 TDV6, now the 2011 Supercharged. Absolutely brilliant!
Post #55718 Fri Sep 15 2006 3:29pm
