![]() | Home > My Range Rover Sport > Battery light |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Possibly alternator on its way out Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
sounds like your alternator is furbed should be pushing out a bit more than that look at the belts to they mat be loose turn on everything lights heated seats air-con and see what voltage you have with engine running |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
try one of these :-
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
I'de put it down to alternator also. I had exact same issues as mention plus i could hear a groaning coming from that area where the alternator is, wasn't sure if it was a tensioner or not. I had my alternator rebuilt using upgraded internals parts, cost £210 for the entire job including removal and refitting been perfect since. |
craigzx9 Member Since: 19 Jan 2018 Location: Essex Posts: 8 ![]() ![]() ![]() |
Hi All
I would start a new topic with a specific heading for this new problem that you have now got. You will probably get more replies with people who have had this problem. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
