![]() | Home > Technical > Key help !! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I would be inclined to think they only changed the ignition lock/barrel and never bothered with the door lock that is why you have two different keys. This is only a guess but they may have removed the internals of the door lock key as there may have been some sort of conflict with the vehicle immobiliser/central locking with two different working keys. The solution may be another lock set change both locks again and have the new keys which come with the lock set programmed to the car if needed.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
good story col.
Don't even recall my pre-facelift glove box being lockable, but it was a while ago, my current facelift hasn't but that could be due to the keyless entry system and to complicated and expensive for L/R to find a way round it.
Cant lock my glove box either |
must having been thinking of another car |
swatkins Member Since: 01 Apr 2017 Location: Essex Posts: 57 ![]() ![]() ![]() |
I brought one of these https://www.ebay.co.uk/itm/Dudely-Remote-K...Sw3WxZ7qH3
Jacksmart123 Member Since: 27 Feb 2018 Location: North east Posts: 2 ![]() ![]() ![]() |
Thanks for the replies guys, my glovebox doesn’t lock, I got in touch with stratstone today and they said the paper work was for the lartsxonly which was a lockset, I don’t think the ignition one has been changed due to the key looking like it’s as old as the car, the key isn’t getting any RF signal so gong to change the battery and see what that does, the guy who came out to try programme a key recommended getting a key from Land Rover to match the chassis and then get it programmed. I have a towbar recall to book in so may do it the same time , I just want it to lock and unlock from the fob!! |
