Home > General > Traction Control Kicks In Cornering |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
First off it’s the DSC which is kicking in is it when going into left or right corners or both ? First check tyre pressures if you haven’t already. Have you had the wheel alinement checked/adjusted recently, might be the steering angle sensor is faulty or needs resetting.
Fri Feb 23 2018 7:40pm |
mattdonut Member Since: 04 Sep 2017 Location: midlands Posts: 11 |
i had this when i picked up my RRS
Fri Feb 23 2018 7:44pm |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 |
I had this problem a while back on my old RRSport because I'd put cheap types on. Got them swapped out straight away and no problems thereafter. Have you got a recognised brand of tyre on? Just something else to consider!!
Sat Feb 24 2018 11:48am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
I've just checked where the car was previously standing and there is definitely something oily underneath where it was. Can't see any drips under the car though. |
Sun Feb 25 2018 10:46am |
There is a tray between the front ACE bar and the road, if there is a leak that will catch all the oil and unless it's a significant amount it won't leak. If you check the reservoir though you will see if the system needs oil (and if it's leaking it will).
Mon Feb 26 2018 1:14pm |
Took car to garage this morning & rear tyres were 42psi, so that might have caused the issue. Fronts were spot on. Still going to check the steering angle sensor. Tyres are AT3s
Mon Feb 26 2018 1:32pm |
