Home > Technical > Re seal or replace air compressor pump |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I think consensus is replace the whole thing.... Visitor from fullfatrr.com
Thu Feb 22 2018 12:00pm |
If you fit the newer AMK type compressor you will need to update the software.
Fri Feb 23 2018 11:23am |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 |
Put into off road mode and removed the relay, removed the compressor quiet easily apart from top bolt, I am going to do a re seal as all in very good condition, local 4x4 dealer wanted £850 to replace, plus £100 if software required, whole job should only come to £75, fingers crossed, will take care with the case, thanks 👍🏻 |
Fri Feb 23 2018 12:45pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
reseal.
Fri Mar 02 2018 11:31pm |
Have re sealed the compressor, was not too bad, re fitted, had no messages on dash, seems to work better than before, so all good so far 👍🏻 |
Sat Mar 03 2018 8:27am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
You say "re-seal", do you know what the problem is?. The plastic end cap (where the air lines come out) have a tendency to crack between the air lines and can be tested by spraying soapy water on it and looking for bubbles. I had this on my D3, bought a cap of ebay for less than £30 and fitted it myself on the drive. No need to take the compressor off, just remove the lower cover.
Sat Mar 03 2018 9:47am |
Pre repair, had warning light on dash to say that normal height only, was slow to lift to standard height, kept saying raising on dash, re moved whole unit, placed new piston seals etc, new cap on air dryer and new internals etc, now no messages on driving, quicker to lift to normal height, all good so far, had no leaks pre repair that I’m aware of, apparently a common problem with these compressors👍🏻 |
Sat Mar 03 2018 9:54am |
My bad, didn't see your pervious post
Sat Mar 03 2018 12:36pm |
