Home > Technical > suspension fault
Tyrefitter
suspension fault
Morning,,A friend of mine has just called in with his 2012 RRS AB & its coming up with all terrain fault on dash,,ive just had scanner on it & its coming up with u0434 suspension control module B & c1b03 direction control valve,,before it goes into LR has anyone any idea what needs changing.?
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #549338 Wed Feb 21 2018 8:19am
I found this, probably no use at all though, looks like six codes beginning C1B03, common bit seem to be Directional Control Valve 1 Solenoid. Is the other code UO434 or possibly UO43A ?
C1B03-
01
Directional
Control Valve
#1 - General
electrical failure
Directional control
valve 1 circuit
short to ground,
short to power,
open circuit, high
resistance, short
to another circuit
Dynamic response
control module
failure
Refer to the electrical circuit diagrams and check
directional control valve 1 circuit for short to ground,
short to power, open circuit, high resistance, short to
another circuit. Check and install a new dynamic response
control module as required
C1B03-
12
Directional
Control Valve
#1 - Circuit
short to battery
Directional control
valve 1 circuit
short to power
Directional control
valve 1 failure
directional control valve 1 circuit for short to power.
Check and install a new directional control valve 1
solenoid coil as required
C1B03-
14
Directional
Control Valve
#1 - Circuit
short to ground
or open
Directional control
valve 1 circuit
short to ground,
open circuit
Directional control
valve 1 failure
open circuit. Check and install a new directional control
valve 1 solenoid coil as required
C1B03-
18
Directional
Control Valve
#1 - Circuit
current below
threshold
Directional control
valve 1 circuit high
resistance
Directional control
valve 1 failure
directional control valve 1 circuit for high resistance.
C1B03-
19
Directional
Control Valve
#1 - Circuit
current above
threshold
Directional control
valve 1 circuit
short to power
Directional control
valve 1 failure
C1B03-
1D
Directional
Control Valve
#1 - Circuit
current out of
range
Directional control
valve 1 circuit
open circuit, high
resistance
Directional control
valve 1 failure
directional control valve 1 circuit for open circuit, high
resistance. Check and install a new directional control
Post #549341 Wed Feb 21 2018 8:33am
Tyrefitter
Thanks Col,,ill let him take it to dealers as its under warranty.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #549343 Wed Feb 21 2018 8:52am
This could be the other bit.
U043A-68
Invalid Data Received
From Suspension
Control Module "B" -
Event information
The terrain response
switchpack has detected
that the adaptive damping
system control module had
operated in a way or at a
time that it had not been
commanded to operate
The adaptive damping
system control module is
unable to support normal
terrain response
Using the manufacturer approved diagnostic system, check the adaptive damping system control module for
DTCs and refer to the relevant DTC index, rectify as required. Check the system is operating correctly and the
DTC does not return. If the problem persists, suspect the adaptive damping system control module.
Post #549345 Wed Feb 21 2018 9:04am
