Home > General (L494) > TPMS on MY17 RRS
dlongson
TPMS on MY17 RRS
Hi
I know this is a frequent topic, but I can't find the answer on the forum...
I have fitted 20" wheels with Pirelli winter tyres as per the RR compatibility list in the owner's manual. I have fitted 4 new LR070840 sensors (which are 433MHz, I think). The tyre fitter says that the TPMS is broadcasting correctly from each wheel. I have driven round the M60 (50 miles!) at a nice steady speed, and done two other 50 mile trips. The TPMS remains in fault mode, with an red 'x' at each corner of the display in the car.
The original spare tyre remains in the boot.
All the forums suggest that the car should now re-scan the sensors, and sort itself out. Any ideas, or is there something I have missed. Is there something unusual about the newer cars, as most of the forum posts appear to relate to cars MY16 or older
Thanks
Damien
Post #549228 Tue Feb 20 2018 7:18am
dlongson
BTW - the car was supplied with 22" wheels
Post #549229 Tue Feb 20 2018 7:19am
Tyrefitter
May I ask where you purchased the sensors.? I got some off fleabay & they wouldn't connect even though the frequency was the same so I sent them back for a refund.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #549235 Tue Feb 20 2018 7:53am
dlongson
From a well established Doncaster-based independent LR specialist (not sure if I'm allowed to name?).
They looked totally new, and the tyre fitters said they were 'awake'. But do the fitters have to do more than they did, in order for the car to see them again. Do they need to go into some kind of pairing mode?
Damien
Post #549238 Tue Feb 20 2018 8:03am
Tyrefitter
As far as I know the car should just detect them.You could always go back to the supplying dealer & ask them to put the diagnostics on to set them.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #549239 Tue Feb 20 2018 8:06am
syl
I'm sure I read somewhere, probably here, that the new (either MY16 or 17 onward) cars have different sensors to the older ones. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #549263 Tue Feb 20 2018 11:44am
DBA
Macedonia
I was in similar situation - MY17, original wheels 22", bought 20" winter tires (pirellis).
We bought the sensors for the new 20" tires from the place where we got the tires and wheels, which were not original LR sensors. They said they have cloned the original sensor software somehow and initially all worked fine, but after a day or two they have failed (seems to me like that happened if there was a path hole).
To test if those sensors are not good, we have returned the 22" tires and all got back to normal by itself.
We have finally resolved the isuse by purchasing original LR sensors from the LR dealer and fitted those...
From that on (month or so) all is fine on the 20" wheels....
Post #549448 Thu Feb 22 2018 1:37pm
