Home > Maintenance & Modifications > Alloys Offset
anton
Alloys Offset
What is the offset of the sport?
Would the below fit?
20"
Et35
Studs 5
Diameter 120
cheers
Post #54919 Mon Sep 11 2006 10:19pm
Did you try to do a search on this i'm sure i'v seen this before RRS TDV6 Gone but still around
Post #54920 Mon Sep 11 2006 10:36pm
anton
yeh i did mate ,i found one for 22s but not the 20s.
I think they will fit but not 100%
Post #54921 Mon Sep 11 2006 10:45pm
Best thing to do if you want an answer quickly is to confirm with your wheel supplier - they should be able to find out for you. Also, if you buy a set of wheels from them and they don't fit it's their fault for providing bad advice rather than ours Wink
Post #54933 Tue Sep 12 2006 8:07am
anton
good answer smoogle
cheers
Post #54943 Tue Sep 12 2006 9:48am
ash001
Sorry for late response but the ideal offset is 40-45. I have fitted 10 x 22" with an offset of 40 and they are fine. As you are trying to fit 20" with an offset of 35, chances are your wheel width is between 8.5 and 9.5. this will give you the clearance you need. Fit the wheels with a 265/45zr20" tyre and you should be ok.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ASH
Post #60062 Wed Oct 04 2006 1:10pm
