![]() | Home > Technical > Stuck in Access Mode |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Welcome to the forum - It's not meant to be driven in access mode for more than a few hundred yards - you will feel every bump & the suspension parts on these motors are notoriously crap - have you tried driving it upto a certain speed - it defaults to normal ride height after a certain speed. What about a hard reset on the battery ? 16MY Estoril Blue SVR.............
Try a hard reset, disconnect the battery cables and touch them together for 20 seconds, then re attach to the battery. |
Gibbro Member Since: 19 Feb 2018 Location: Bristol Posts: 14 ![]() ![]() ![]() |
I have driven it up to 40 mph and it still remains in access mode. This makes me think it's going to be the new compressor they fitted. When the key is in the ignition and turned on the light shows from the off. Will try the hard reset though, thanks. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It's more likely to be a height sensor that needs re-calibrating than a fault with the compressor.
Have a look on the 4x4 screen to see if any of the corners are showing different |
Morning guys,
Vehicle raising slowly might still be down to a dodgy height sensor, but it might be that you have a second issue in that your compressor is weak (the compressor being weak wouldn't cause the other fault). |
