Home > Technical > Suspension rasing rear ok front very slow advice needed |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 |
It puts the rear up first. Probably using capacity in the tank to start with.
Sun Feb 18 2018 3:43pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
leaking air reservoir |
Sun Feb 18 2018 4:06pm |
RRS2012 Member Since: 02 Feb 2018 Location: Sheffield Posts: 13 |
Thanks chaps. It feels like Mikey has the most likely suspect. Once its at any height it stays there, over night, over a weekend etc no issue.
Sun Feb 18 2018 5:02pm |
people have been known to hear them when the leak is bad
Sun Feb 18 2018 5:28pm |
I’m not as convinced it’s a leaky reservoir anymore. I left it in access height for about three hours and thought if there’s a leak and I jump in and try to raise it it’ll struggle as before as it’ll be doing it on a empty tank..:. It didn’t, jumped in, started her up and immediately raised to normal height in around 5 seconds.... and evenly rear and front in sync
Sun Feb 18 2018 10:22pm |
Sounds like a weak compressor to me (or an air leak) especially if it's overheating!
Mon Feb 19 2018 11:35am |
Requires less air pressure to go from access>normal than from normal>off road That said, it could also be a worn compressor not filling the tank fully, masked by the fact it is overheating and switching off... |
Mon Feb 19 2018 12:00pm |
Ok guys, thanks for your help and comments. Heres where I need your thoughts/comparison on what you experience with yours and if mine is in fact normal, on the border of normal, or potentially needs some investigation
Sun Feb 25 2018 12:35pm |
It's a little unfair and not typical operation for it to go from access to off road.
Sun Feb 25 2018 1:25pm |
Thanks Andy.
Tue Mar 20 2018 6:27pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
refurb the compressor.
Fri Mar 23 2018 7:35pm |
It could be ok as is. What do you guys get timing wise from a full air tank through the range? As questioned above? From what I can gather it’s variable vehicle to vehicle. The tech instructions for example say when calibrating the height, allow 5 upto mins to reach off road height.
Fri Mar 23 2018 9:52pm |
If it carries on going to extended when lowering to access its usually:
Sat Mar 24 2018 9:56am |
Mart Member Since: 03 Jan 2019 Location: Sheffield Posts: 15 |
Hello
Thu Jul 11 2019 7:41pm |
