![]() | Home > Technical > Headlights on all the time |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
sounds very much like Scandinavian or Canadian modes set in the CCF
Sounds like, Canada Spec daylight running lights. Do the lights go out when hand brake on and in park ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Hi guys and thanks for quick response.
Scandinavian then |
I presume then I need a BT iid tool or somebody with a tool that can reset the lighting. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
yeah, or ask the LR dealer if you need to go back for something else |
Thanks Andy, I presume it is only a 5 minute job to reset. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
yeap, if they know what they are looking for and how to do it |
Well.......I was passing Range Rover Stafford so I thought I would pop in to see if they could do it and how much it would cost.
Thats about par for a Land Rover dealer not a clue and will not listen to a word that a customer has to say unless you want to buy a new one lol |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
That sounds about right!
Went to the indie in Stoke called Landranger, brilliant chap there, plugged the car in, showed me on the screen that 'scandinavian was enabled. Simply pressed the button to disable, updated the records and job done. cost me £36 and happy with that.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Don't you just love 'em?
