![]() | Home > General > 4.2 V8 Supercharged |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
13mpg more like.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I would say on average running a S/C would double you annual fuel bill, weigh that up against the possibility of a 18k bill if the 3.0 goes pop and not covered under warranty. So if average annual fuel was 3K it becomes 6k divide 18k by 3 (as you are already paying 3) = 6 so you get 6 years fuel at no extra cost. Easy to convince your self you want one. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Not just potential crankshaft failures, generally speaking, petrol engines are often more reliable than modern emission complying diesels, especially over low annual mileage.
But i do enjoy pulling my 1800kg caravan everyone looks as you pass them uphill or on a straight off the lights etc |
Was Dynamc Response an option on the early Superchargeds?
Mine has it as I have the yellow topped bottle on the other side and its a 2005 |
Thanks. Looks like no dsc so less to go wrong |
A bit like jelly then was that one not up for auction as well looks very similar |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Wish mine didn`t have it. Steve. |
A few issues then Steve |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Mine's also a 2005 SC and has the second yellow capped bottle but looking at the build sheet I think it's for Active Cornering Enhancement (ACE) or Stability Control System.
Mine`s the ACE sorry...the tippy over prevention thingy. Mine comes on randomly... ![]() |
All RRS have DSC, like all cars built since about 2000 - it is the control that kills the engine if the ECU thinks you are trying to crash the car - there is a switch because in some conditions (off road or in deep snow) when you have to disable it. It is called different things by different car makers and it is legally required and required to be working. It can be over sensitive in some cars but LR seems to have got that bit right!
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
I test drove a 2.7 without the active anti roll bars and a 3.6 with active anti roll bars, back to back. Handling was far better on the 3.6, I probably wouldn't buy a sport without them. Reading the owners book, I'm sure it said pushing the dsc button disables the active bars but leaves traction control active, and there's no way to disable it. |
