Home > Faults & Fixes > Does the headlight bulb need changing?
Kashiy
Hi All
Hope someone can give me advice as to if I need just to change the low beam bulb in my RRS TDV8 2008 or if its something else.
Normally if a bulb needs changing it stops working. This however has changed to a different colour , more a brown red hue.
Ive attached a picture showing the difference in colour.
Any advice would be appreciated.
Post #548772 Thu Feb 15 2018 10:28pm
GodivaNige
Yes, you have a Xenon bulb and the red tint is an indication it is about to die. Needs replacing
They often turn pink initially as the bulb decreases its ability to emit at the violet end of the light scale, as it now appears red/brown, the bulb has seen better days. New bulbs please Laughing Thumbs Up
Post #548776 Thu Feb 15 2018 10:41pm
Kashiy
Superb info ! Many thanks!
Post #548778 Thu Feb 15 2018 10:43pm
Kashiy
Any recommendations for decent xenon bulbs?
Im assuming they are D2s?
Post #548779 Thu Feb 15 2018 10:51pm
I like Osram's "XENARC NIGHT BREAKER UNLIMITED". Nice white light without being blue so it's near to the original colour but just a touch whiter. Good brightness and even light output - some cheap bulbs can have inconsistent light output across the road for some reason. Osram do a Nightbreaker in H7 halogen too so you can get the same colour on the main beam fill-in lights.
The bulb type is given on the top of the headlight unit - it's moulded in to the "glass" and can be read when you open the bonnet. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #548784 Thu Feb 15 2018 11:52pm
Kashiy
Nice one.
Ordering a full set of nightbreakers
Post #548793 Fri Feb 16 2018 9:40am
flydive
Do not assume, check. Wink '08 RRS TDV8
Post #548906 Sat Feb 17 2018 9:26am
