Home > Technical > RRS 2010 Front Anti-Roll Bar Bush Replacement. How to....
clarkey1
Hi Guys,
I have searched but couldn't find it, it must be in here somewhere.
How do you replace the front anti-roll bar bushes. The clamps and the 3 bolts(per side) are on the top side of the cross member. So looks pretty fiddly.
Whats the best way to tackle this ?
I got the bushes and want to replace them, obviously I get a knock from the front when going over bumps. Upon inspection we found the anti-roll bar slopes side to side (very easily) in the worn bushes .
Point me to the right place please
Thanks
Post #548611 Wed Feb 14 2018 6:20pm
geoffsnook
Has it got a warranty if so take it back Thumbs Up
Post #548612 Wed Feb 14 2018 6:33pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
You need to remove the under trays front and back. Then remove the front prop from the front diff and push up out the way,
You can then get to the bolts with a shallow socket and ratchet or ring spanner.
You may need to use some leavers or a bar on the end of your spanner as the bolts a really Censored tight .
You can only turn some off them a bit at a time so be patient .
Remove both clamps at the same time so You can swing the bar left to right to swap the Bush's .
Swear a lot through the whole job.
It helps
Post #548616 Wed Feb 14 2018 9:09pm
clarkey1
Thanks for the help with the advice.
a job to do a bit later.
Post #548723 Thu Feb 15 2018 5:42pm
