![]() | Home > Maintenance & Modifications > CTEK towpug connector. Anyone use one? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Had to turn out home start for the RRS today. It started on a jump pack and the chap tested the battery and alternator and both ok (big sigh of relief). Short journeys and heated seats etc probably the cause.
I use one and itβs a top bit of kit, just plug it in the tow electrics and leave the car locked. Just remember to disconnect before driving off! |
Thanks for the feedback. I'm not confident enough to cut into the wiring though.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
charging through the tow bar is excellent and very easy. I only cover around 5-6k a year and nearly always use remote heat through winter, so I like to top up the battery every week.
yep, noticed that when I read it properly |
The connector is a good bit of kit. Got one that I use with my Ctek. |
Rich Member Since: 14 Nov 2014 Location: West Sussex Posts: 39 ![]() ![]() ![]() |
I'm another very satisfied user. Use it every week or so during winter. |
Andy K has hardwired a CTEK connector onto the (tow bar?) wiring in the boot which is a very elegant and cost effective solution |
Got it |
