Home > Maintenance & Modifications > automatic activation of front & rear demisters ? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Mine does it too. It only happens in low temperatures and appears to be a function added by LR during the facelift. Earlier RRS didn't do it. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 03 2018 5:21pm |
No nickname Member Since: 06 Nov 2016 Location: Copenhagen Posts: 17 |
This explains why the battery is nearly flat all winter time |
Sat Feb 03 2018 5:53pm |
Only if you do short journeys, I would suggest. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 03 2018 5:59pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Mine does this every time you start the car if the temp is low and the snow flake is displayed. 4 degrees or below I think.
Sat Feb 03 2018 7:44pm |
Indeed so. They can be turned off by pressing the buttons so it's not a real issue. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 03 2018 9:22pm |
That's exactly what I do if they don't need to be on. 2 button presses problem solved 2017 SVR. SVO Scafell grey Ebony interior
Sat Feb 03 2018 10:19pm |
My heated rear screen is on even when the buttons aren’t turned on,,must be a fault on it so I’ll mention it to LR when it goes in for next service
Sun Feb 04 2018 9:15am |
