Home > Technical > Are your Front Fog Lights working + Access to Interior Fuses |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Normal and a complete PITA |
Sat Nov 14 2009 10:05pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Don't even attempt to replace the Front Fogs Fuse! (or many of the others for that matter) Unless you have hands the size of a small baby or African pigmy I had exactly the same problem and after lacerating the back of my hands and dropping the fuse replacement tool inside the bl dy dash assembly whilst trying to access the spares I gave up and got my dealer to do it! Much less hassle & definately less painful 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Sun Nov 15 2009 11:16am |
I lost the spare fuses getting them out IIRC - better off buying spares from Halfrauds and keeping them in the glove box - fitting them is a right PITA |
Sun Nov 15 2009 11:20am |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
The easiest way to get to the fuses is a pair of long needle nosed pliers...gently grab the fuse and pull as straight back as you can, the fuses come out very easily. You can also use them to put the fuses back, line it up and gently push in.
Sun Nov 15 2009 4:44pm |
IIRC the red plastic 'tool' centre top of your pic is for removing and replacing the fuses |
Sun Nov 15 2009 5:38pm |
that is true, but I find it's also difficult to use in tight spots...so the pliers give you quite a bit of added reach and keep your knuckles from getting rapped in there...give it a shot. PJPR Cairns Blue HSE 180k Miles of Adventure |
Sun Nov 15 2009 7:39pm |
Oh i agree - just thought there will be some that didn't know |
Sun Nov 15 2009 10:24pm |
MAW... PJPR
Sun Nov 15 2009 10:49pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
Good advice and when the the warranty runs out that's the route I will go but I think I will let the dealer drop fuses in there for now. Anyone had their dipping mirror fail to dip? - may not be the fuse at all. |
Mon Nov 16 2009 10:32pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
hi all
Tue Jan 30 2018 1:34pm |
anyone? Merc C220 estate Sport AMG
Tue Jan 30 2018 4:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
squeeze the lid supports at the sides
Tue Jan 30 2018 5:12pm |
thanks, I'll have another look (when it stops raining). Merc C220 estate Sport AMG
Tue Jan 30 2018 10:12pm |
