![]() | Home > General > MY10....gearbox warning on dash! |
chandelierman Member Since: 05 Dec 2012 Location: ESSEX ENGLAND Posts: 6 ![]() |
Just to jump on the ban wagon and add my 2 pence worth........I had a Range Rover,not a Sport but a L322 that developed a gearbox fault......i used to turn off the ignition then it would reset ......this soon turned into warning light = limp home mode.........anyway,I took it to a 4x4 back street garage and he said that there was a short loom in the gearbox but he didn't have the right software to make sure so he advised I took it to main dealer ....I did as he said and that's when the fun started.
Mahrenholz Member Since: 16 Feb 2014 Location: UK Posts: 15 ![]() ![]() |
Hi guys
s1ras Member Since: 02 Sep 2010 Location: Windsor Posts: 36 ![]() ![]() |
Common fault |
Finndog Member Since: 30 Nov 2015 Location: Henley on Thames Posts: 6 ![]() ![]() ![]() |
yep me to same thing transmission fault popped up on the screen the day I picked up my rrs 2006, got home ok all seamed ok, restarted it next day no problem! |
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 ![]() ![]() ![]() |
Mine was sorted after I changed the battery🙈 |
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 ![]() ![]() ![]() |
I had a 'Transmission Fault' error appear on my dash - turns out there was a loose, previosuly repaired wire behind the console that needed replacing. This sorted it for me. 2008 RRS HSE Stornoway Grey |
Hairy_Goose Member Since: 09 Mar 2018 Location: Rugby Posts: 2 ![]() ![]() ![]() |
I suffered this on a 2007 Sport. Tried all the usual |
eqerem Member Since: 26 May 2018 Location: Tirana Posts: 2 ![]() ![]() ![]() |
Dear All,
