![]() | Home > General > Smashed fog light on my Sport HST..... Great |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
ebay...or you could get a couple of led ones to update yours a bit.. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
The problem you have is the non HST replacement foglights are readily available, I bought a pair of aftermarket lights from PowerfulUK and they are pretty good quality, but won’t fit a HST. Sadly, you may have to fit an original LR light which are not cheap, £102 from PowerfulUK |
Here you go, a little bit cheaper... for the HST
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If you can pick up one of these L/R Lamp Kits VUB502440 cheap, there was a dealer selling them a while back for around £30.00 a kit. The kit contains amongst other bits, 4 lamps a pair are the normal size HSE lamps and a pair of smaller one's which are the same as the HST. There was plenty of these kit's around as nobody bought them as they retailed at over £400.00 each and look like a carbuncle (personal opinion) on the bumper any way.
