![]() | Home > General > spare tyre pressure sensor |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Although the TPMS system on a RRS1 is about as much use as a chocolate teapot, if it has a full size spare it may well have a sensor fitted as it is/was a option, if you check your spare wheel if it has a sensor it will be a metal valve stem, if not chances are it will be a rubber stem.
a spare sensor is more useful.
Alfa Rover Member Since: 15 Dec 2016 Location: Vancouver Posts: 19 ![]() ![]() |
Thanks Col and Andy, good points. it has been raining quite heavy for days here and could not bring myself to crawl under to have a look. there was no light on the dash, trouble code, just scanning codes for my blinking PDC rear parking sensors. all of the sudden i see this spare tyre code. soon as it stops raining an under carriage look see is in order. Thanks for your help. Cheers Neil. |
