Home > Wheels & Tyres > time for new tires - mainly road recomendations requried
PC76
Hi all,
After replacing my lower arms last night and getting the car aligned this morning i am looking for a set of new tires.
I will be using mainly on the road and some off road use for site surveys up in Scotland, forestry tracks, fields and the odd mountain track Smile
Have seen people recommending the AT3's but they seem to be hard to get hold of round here, are there any other recommendations for 20" wheels.
Thanks
Post #546897 Sat Jan 27 2018 3:02pm
qcnr
Norway 2007 Range Rover Sport TDV6 HSE Lux Buckingham Blue
What size are you thinking of?
Post #546921 Sat Jan 27 2018 5:39pm
Stevepd
I've got Michelin latitude sport on my 20inch summer wheels, also noticed they have M+S on them.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #546923 Sat Jan 27 2018 5:53pm
Tyrefitter
Here you go PC76,,their is a few Protyre dealers round Cheshire,they are owned by Micheldever who are the main distributor for General tyres in th Uk.
https://www.protyre.co.uk/search#/car/275/40/20/any/any/all
andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #546925 Sat Jan 27 2018 5:58pm
PC76
Cheers Andy.
Thinking of 275/45/20 qcnr as that what AT3’s are available in..
Still open minded tho.
Post #546930 Sat Jan 27 2018 6:34pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Same size as mine and I have Pirelli Zero's which are proving well up to the job. I too do mostly road driving. Had no issues with these in all weathers. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #546960 Sun Jan 28 2018 9:08am
PC76
decisions decisions.
can somebody tell me what the AT3's are like in the rain in fast corners?
also which profile gives the better handling / ride and that look good on 20" rims.
Post #546983 Sun Jan 28 2018 2:07pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I have found the Pirelli Verde All Season to be an excellent tyre in all conditions.
Jim
Post #546984 Sun Jan 28 2018 3:21pm
Tyrefitter
Ive got these fitted to my SC,,I know they are different size but you can get them in 20”,,ive never had problems In dry or wet weather & I do drive it like I stole it as long as the weather allows,I wouldn’t like to take a Corner at silly speeds in any vehicle even with top end tyres,I always drive to the condition of the roads.
https://www.bridlington-tyres.co.uk/TyreSe...T+27540R22
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #546991 Sun Jan 28 2018 4:36pm
I have Grabber AT3 on 19 inch rims and they are excellent in all conditions - remembering that they are an all terrain rather than tarmac tyre. They are better than the Grabber AT all round and certainly better in the wet. They are quieter too. 2012 SDV6 - it's missing a couple of cylinders
Post #547007 Sun Jan 28 2018 7:00pm
PC76
Still thinking of the AT3's is there any issues with the speed rating of H, the info plate says Y?
Post #547039 Mon Jan 29 2018 12:42pm
The speed rating (H) is the max speed (130mph) that the tyre is rated to carry its maximum load. Are you likely to want to exceed 130mph 5-up with luggage? No? Then it's not a problem... Wink
Being serious, General shows the 275/40/20 as now being available in H and V ratings so you should be able to get one that you're happy with. In both cases, the load rating is 115 which is much higher than that required for the RRS. Interestingly, online suppliers show the load rating as being 106 for both speed ratings so I guess General are making them more robust from now on. 2012 SDV6 - it's missing a couple of cylinders
Post #547080 Mon Jan 29 2018 10:01pm
HughN
Wales
I've just fitted Grabber GTs all round. Had them on our D2 for years and they wore well - drove well several times on Salisbury Plain in the muddiest mud you can think of.
Post #547152 Tue Jan 30 2018 7:23pm
PC76
Well took the plunge and had a set of AT3's fitted. went with the 275/45/20 110H £350 all in.
They have certainly filled the arches so will ensure i calibrate my suspension just for peace of mind.
one question i have is there is a strip of balancing weights about 30cm long on one of my wheels... is this normal or bad practice? why should they require so many weights?
Post #547155 Tue Jan 30 2018 7:53pm
PC76
can anyone recommend what pressures would you run in the AT3's on 20" rims.
Thanks
Post #547170 Tue Jan 30 2018 10:27pm
