Home > Technical > Front bumper removal - screw in the wheelarch...
wakeboarderspan
I've got a problem with my front left parking sensor so trying to replace it (annoyingly it knocks out the rear sensors too! Mad ). Anyway, I've managed to get off all the bolts under the car (a real pain), but the final 2 flathead screws that hold the bumper on inside the wheel arches I cannot get off.
Anybody got any advice on how to remove these? They are jammed solid and the heads are pretty much disintegrating. I'm thinking I may have to cut them off but don't want to damage the bumper...
Any advice is appreciated.
Post #546805 Fri Jan 26 2018 11:01am
yeah ones under the car are a real pain
I assume you have removed the wheel and used the correct sized bit?
I've had to cut off ones in the rear arch before
Post #546807 Fri Jan 26 2018 11:11am
wakeboarderspan
Yep, got the wheels of and using the correct bit... looks like it may be a cutting job then Sad
Post #546808 Fri Jan 26 2018 11:13am
Morgi27
Yeah I had to do the same yesterday to replace bumper the ones underneath the car are a pain and torx heads which I think makes it harder
The 2 screws inside the wheel arches 1 each side on mine were the plastic type and came out easy
Post #547044 Mon Jan 29 2018 2:19pm
Lucifus
United Kingdom 2009 Range Rover Sport TDV6 S Java Black
I think I read a post from someone who said you can reach those sensors if you remove the grill and headlights.
Post #547077 Mon Jan 29 2018 9:49pm
